mmf
Got a good bit done to the boat today, got a little fustrated at one point on the wiring. I reused the original fuse block assembly which "looked" good, wired up my console switches and sorted out unused wiring then went to the battery compartment and cut off the fuse block to battery terminals and fuse. I replaced the main fuse with an automatic circuit breaker and crimped on new terminals to positive and negative, then I went to fuse block with my meter and found zero volts on the buss. I traced it back to the original tracker multiwire connector and found the pin for the 12 volt main line was broke off in the female connector so I butt spliced the wire to the buss. Tried the running light switch and NO lights, so I went to the fuse for this circuit and found highly oxydized fuse clips. I sanded them with no good results so I finally made the decision to rip out the old fuse block. I had some DIN rail and some Siemens circuit breakers of the proper amperage in my building so I installed all of this and re-terminated all of the wires. Finally I have voltage where it is supposed to be! Oh well, so much for trying to re-use old crap. Forgot to say I installed an under console horn as well.
Got my drivers seat base drilled and installed too, then riveted the BIA plate on the inside wall of the boat and installed the HIN plate on the rear of the transom.
I still need to make a new bilge pump MTG bracket and wire it up and I will add interior lights, fuel compartment lights and switches. Daylight is getting shorter and soon they will change the time and make the daylight even shorter! Still alot of little ends to tie-up before I can say "let's go fishing".......
