- Joined
- May 15, 2010
- Messages
- 3,721
- Reaction score
- 411
- Location
- Central Florida
- LOCATION
- Lake County, Central Florida
50# compression will never support a strong idle in a two stroke.
Second clue was the smoking issue. Engine had prob. been overheated and stuck by the previous owner and passed on to you. Sounds like it overheated again.
What has happened to the engine in question is the pistons have stuck, scoring both the piston and the cylinder walls.
Chances are the rings are mechanically stuck (by metal not carbon).
The damaged piston skirt and cylinder is now well outside the recommended factory clearance. When this happens the engine loses the tight seal needed for crankcase vacuum on the up stroke and crankcase compression on the down stroke. NO....not the compression you measure with your gauge.
This seal, inside the crankcase, is what creates the pulses to suck in and "blow" the incoming charge up to the top of the piston for the following power stroke. Loop charged engines are much more sensitive to this than a cross flow.
Here is a tip.
When buying a used two stroke engine make sure the engine is capable of a good strong idle.....on the water, not on a hose. This will indicate good crankcase compression. The lower the engine idles the better condition the rotating assembly is in.
If the engine gradually slows and shuts off that is your first clue to lack of the above.
If a two stroke engine will support a good strong idle I will just about guarantee it will run well at WOT.
As always....check the other stuff out that has been covered here a million times already.
Here is a tip.
