russ010
I used Brightside Interlux which is a Polyurethane... I sprayed it on in 3 thin coats and it worked awesome, but I used zinc chromate as the base primer after etching the boat up a little bit. I've scratched it up pretty good on the bottom because of all the rocks where I fish, but it's holding up well everywhere else.
On the inside I use spray cans of paint in a metallic black. I was going to spray it too, but I got a head of myself and started installing decking with carpet before I realized what I was doing. It looks good and I only put one coat on... it hasn't started scratching or peeling yet, it's pretty durable.
You can see the process I used HERE
