Henry Hefner
DryFlyRy said:Im no electrician so maybe someone could give me a heads up of any mistakes or problems I'll run into if I go this rout (such as can I daisy chain the lights like that? or do i have to wire each one individually?). let me know what you think.
My drawing isn't as pretty as yours, but I think my circuits are sound. Lights should be wired parallel, not in series. Also, I didn't see any fuses in that diagram, if your panel doesn't have any I would add them. For example, if your wiring shorts out on a circuit, even if it doesn't cause any other damage it will melt wiring all the way back to your battery and drain the battery in a hurry if not worse. Here's my corrections:
