Duramacr said:Not bad , your boat weighs just 10lbs more then mine
And your engine is 40lbs more. I thought you would at
least be at 33mph with 2 people. I came back from the lake
yesterday and I'm running 28mph with 2 people and 30.5
with me alone . But I have a 2015 Merc 20hp. Where you
in the ocean or something . I was under the impression that
extra 5hp would get me 4-5mph especially with that 3rd cylinder .
Buy hey thanks for heads up. I might just go straight to a 30hp
and finance it . Thanks again.
or need to # 2 really bad.[/quote said:If thats all I'm going swimming...just swim upstream..
Trolling in and out slow is thee flat out worst thing you can do with a 4 stroke outboard, they are designed to run hard,not 600 rpms. I understand if your trolling for fish but you should also do some wot every time you go out because you will never get the engine up to temperature. If I'm going to troll I would not invest in a $4000+ outboard because a 9.9hp or 15hp would be plenty fast to get away from weather. There is a guy across from me I'm my canal who never does anything but a mph in the canal and never goes to open water to run it and it's a 25hp etec with the works,imo a complete waste of money when a 6 or 8hp 4 stroke at less then half the price will do the same exact thing. Me,imo use my outboard as intended,balls to the walls out of the box and I troll very little, if I was going to troll all the time I would get the lowest hp 2 cylinder engine available for the cheapest price because I'm going 1 to 3 mph anyways and it will troll as smooth as a 25hp 2 cylinder for way less money. I live in fl so weather here in summer turns bad in minutes and even with my 9.8hp 2 stroke tohatsu I used to have in out ran hellacious thunderstorms. Like I said this is my opinion.bcbouy said:for me personally, speed only becomes a factor when i'm full tilt back to shore while outrunning weather or need to # 2 really bad.i'd rather troll nice and slow out and in. my main criteria were smoothness,reliability and first and foremost power tilt.could not get that in anything but my 25 tohatsu,even then i'm 5 horse over my rating.
DaisyCutter said:Well, it's mid March now.
I ordered my Alumacraft utility boat at Cabela's on December 23rd, 2016. Still no boat, still no motor.
Tick-tock-tick-tock...
