Brandon
Brandon said:Update: Carb kit arrives this afternoon
Question: When I took the carb off of the motor, I noticed that inside the bowl(which is glass), the threaded disc that holds the float? up was loose. (I wish I had a picture of it at the moment but dont). The disc is threaded which screws onto the nozzle? Should this be tight up against the float?
Do I have this correct? If need be I will post pictures later today. Thanks!
Nevermind! Once the rebuild kit got here I was able to figure out everything. Now....time to rebuild the carb.
