It's always the little things. I rushed home early from work to finish the boat enough to get a weekend camping and fishing trip in. I knew it wasn't going to be perfectly complete, with no seats, and only a few rod holders. So after Patrick and his two boys arrived all five of us headed to Lake Georgetown for the Shake Down cruise.
The fist thing after the launch that was painfully obvious was that we were taking on water at a pretty rapid rate. No problem said I, we have a bilge pump; flip switch...nothing! Flip switch a hundred more times, pull panel check fuses, check wires; all seems fine, but still no pump. So I hit the lake at full throttle and pull the plug to drain the water. Get back to the dock load everyone up and head to camp.
After we got unloaded and camp set up I headed out alone to find the source of the water leaks. I had neglected to seal some of the rivet holes where I removed stuff from the transom, like the handles. There are five or six big ole holes not sealed and that is where the water was coming from. The bilge also started working while I was out there and has worked the whole time since, I don't know what was wrong with it.
So Saturday we hit a couple of spots looking for crappie, and ended up catching a few, but the wind was pretty wicked and the boat traffic was high. We ended up heading over to some big rocks up river and swimming for a few hours; letting the kids jump from the rocks and get sunburnt. We had a good time,even if we did need to run the bilge every hour or so to get rid of water.
The trolling motor also pounded loose in the heavy water. The self tapping screws I used just pulled out. I need to use toggle bolts something in that Alu. to get a real good hold. I think the seating is going to work out okay; especially when we only have three on board. Five people is too many in this boat for any type of seating; no matter what you will be crowded. But for three people my seating arrangement will be fine. The seats are on order and I need to do a little prep work before they get here. But I will keep everyone posted.
Trim of the hull is very good. With just me and Gage it sits perfect in the water. The motor is in the perfect position and I am playing with the tilt for that perfect ride. The Transducer sprays water all over the place. With just me in the boat and all the fishing gear, we ran a little better than 18 MPH on GPS.
So I have a little work to get her ready, but all in all it was a good shake down cruise.
Pictures, of course...
