It looks like rain the rest of the day but I managed to get some of the wiring in the shroud and zip-tied up.
Pictures as promised.
Engine first: This motor was so filthy I was afraid I wouldn't be able to get it clean without tearing it down. The fuel lines had been leaking for sometime and the bottom of the cowling had about 1/8 to 3/8 of an inch of grime and more built up in the corners. A couple of cans of Acetone and some carb cleaner got her looking good as new. You can see the missing paint where the years of gunk caused it to come of during cleaning. I am not much of a boat motor mechanic but I am very pleased with how well she has turned out. Things I have done are, carb rebuild, replaced some of the linkage for choke and low speed control, thermostat, seal and gasket, rebuilt fuel pump, new fuel lines, new plugs, new kill switch, new lower unit lube and MAJOR cleaning of everything!
Front view of the new kill switch, it's a Sea Sense, very easy to install.
Starboard side view, re built fuel pump and lines.
Aft View, new plugs and removed the most grime from this area. I guess it had been stored on it back and it was FULL of gunk back here.
Port side nice and clean.
Rebuilt the carb, this was easier than I thought, The nice white plastic pieces are the new ones I installed.
And here she hangin' on the transom.
She is due for a paint job, but for now she runs and that is a major hurdle for me!
