Are you using an OEM ride plate, or did you fabricate one?
Reason I ask is because I'm using a ride plate fabbed from 1/4" aluminum plate, and to combat porpoising, I bent a very slight downward angle on the last 2 inches of the plate.
With an OEM ride plate, you could still weld a tab on the back end, at a downward angle, and it would have the same effect.
