Just curious I have a gmc terrain 2.4 it only has front wheel drive and im wondering if its gonna be ok towing it and launching & leaving the ramp areas? Just a little concerned with front wheel drive at a boat ramp and only being a 4cyl.
I second that. I’m sure I could of pulled my old 14 foot Klamath with my 1.8l Corolla. Stopping is the main issue though.onthewater102 said:My 1436 rides behind my camry just fine. Launches are one thing, and I too stick to the better launches with the FWD, but watch the vehicle's rating because you want to make sure the brakes can handle the extra weight at speed.
I drive on beaches to surf fish alot. You need to air down your tires to around 12 to 15 lbs and you will not get stuckppine said:Depends. Unless you are towing a really light boat under 14 feet or so, you need a better tow vehicle.
Last fall I lost power and ended up going ashore at a place far from the boat ramp. I got my one ton Ford diesel down to the beach which was gravel. I was careful not to back the rear wheels in very far. With some help we got the boat on the trailer. I eased the truck forward and proceeded to bury all 4 wheels into the gravel. I got out by using another pickup with a tow strap to help pull me out.
Then I went out and bought a kicker motor.
