The factory 11 1/4" is a GOOD prop for what it is. HOWEVER, they blades are a little thin and they'll bend, umm, fairly easily. Same thing for the 10 1/2". If you're going to be loaded, yeah a 10 1/2" is a better bet, OR a 10" SS. If you can raise the motor on the transom, that'll help some-and you may be able to get away with a 11 1/4" with some load in the boat. I run mine with a 1 1/4" spacer between the transom and the motor-and the motor is clamped RIGHT at the top of the "cap"-and hasn't moved (yet). My old F25 was the same way and it was considerably heavier so I'm not scared of it. The clamps actually run off of the very top of the cap a little bit.
Solas=thick cast blades, lots of drag, lose some RPM compared to a good quality SS prop of the same pitch. In my case, .25-.50mph slower on the top end.
Powertech=didn't try much of their different lines, OTHER than the SRA, which is way too much rake. No faster but it did induce some porpoising before I moved the pin.
Have not tried Michigan.
Turbo Hotshot works just as good as the Powertech, but comes out of the hole a LOT better. It actually holeshots as good as the factory 10 1/2" pitch but has nearly the same top end as the 11 1/4". Good rake, works pretty good for all-around use. I used to have to change props if the GF went fishing with me from the 11 1/4" to the 10 1/2" but don't have to do that now with the turbo.
After I bought the Turbo I found out that Turbo is owned by Yamaha. I also found out some other things too that I can't really discuss publicly but I can tell you that to my knowledge, no other mass production propeller manufacturer scrutinizes the quality of their product as much as they do. If it's not exactly what it's supposed to be, it gets melted down. It takes roughly 30 days to make a prop once you consider all of the steps that they take and I believe it....since when I ordered mine, it backordered and took a while to receive it. Also if you order a turbo prop from a Yamaha dealer, it comes free shipping.
I tried a 4 blade Powertech too and LOVED how smooth it ran and how well it came out of the hole and held plane at a lower RPM, but it was a 10" and I should have gotten a 9". Struggled to reach 5500 but still ran 27 mph.
I'm off today...sun just came out....I'm outta here, with a stop at the bait shop!
