16ft mirrocraft flats conversion
Analog Kid
I suppose I should start off with a brief introduction. My name is Grant I live in orlando I do more freshwater fishing than anything. Almost exclusively in lake Conway but I have always loved saltwater fishing more specifically SHALLOW WATER fishing and that's what my goal is for this tin to make a comfortable shallow water fishing machine to use in the Indian river and mosquito lagoon
ImageUploadedByTapatalk1397432355.419536.jpg here it is before I started the official build ImageUploadedByTapatalk1397433844.747162.jpgImageUploadedByTapatalk1397433882.333802.jpg
This is my first aluminum boat and my first documented build but I have been looking at all the other builds and got some inspiration to start my own thread. I had already been using this boat for about a year and my outboard recently took a crap and wouldn't start anymore which. Was kind of the catalyst to start the transformation
ImageUploadedByTapatalk1397434547.888250.jpg not what I wanted to see
ImageUploadedByTapatalk1397434649.803053.jpg first I took out the console and the deck. I made this deck about a year ago it is solid as a rock and twice as heavy! Not good for gettin skinny! Glad to see it go ImageUploadedByTapatalk1397434765.093664.jpgImageUploadedByTapatalk1397434868.460817.jpg
ImageUploadedByTapatalk1397434928.525608.jpgImageUploadedByTapatalk1397435025.772851.jpgImageUploadedByTapatalk1397435188.038785.jpg my brother and I flipped the hullImageUploadedByTapatalk1397435220.548587.jpgImageUploadedByTapatalk1397435241.754679.jpg ugly patch from previous ownerImageUploadedByTapatalk1397435313.096198.jpg
Wondering how to get these damn seat brackets off and have it look nice
ImageUploadedByTapatalk1397435424.165701.jpgImageUploadedByTapatalk1397435457.204592.jpgImageUploadedByTapatalk1397435472.007585.jpg
Last one is patch from outside the hull
I plan to strip the entire hull inside and out and start from scratch because it is chipping off quite easily and I plan to keep the boat for a long time any tips to remove the old paint ? I prefer to make my work easier whenever possible I think there is enough pics to keep the wolves at bay for another work week
    142.1 KB
Also this is kind if what I'm trying to build classic flats skiff style I would like to go with a tiller set up. Not sure if I can retrofit my remote model to tiller. I like the idea of a small coffin box livewell in the center with a grab hoopImageUploadedByTapatalk1397436079.733240.jpgImageUploadedByTapatalk1397436091.254406.jpg
Looks like a good start. I'm wondering how skinny a v hull will get, say vs. a flat bottom.
Either way, I think you are on your way to a great fishing vessel.
It is a modified vee and a good portion of the hull is fairly flat with a slight dead rise to the rounded chine. I have fished this boat very shallow on lake Conway fl easily gliding in less than 12" and I had the previous "dock" installed. And the boat is quite wide to help get shallow. About 6 feet at the gunwhales maybe 5-4 at waterline
ImageUploadedByTapatalk1397442410.469541.jpghere is one of the pistons from the 35 evinrude. Pretty scored up and worn rings. Rebuild is in process
