So I finally got some time this weekend to finish stripping the last few feet of the hull. so i got that done and one more pass on both sides since it has been sitting for a few weeks before going for it with the paint.
I went back over both sides by hand with some 80 grit just to rough it up one more time just before painting.
then some masking, I decided to go to the bottom of the chine sense that is where the seem is and it made for a nice look between the topside paint the bottom paint I plan on doing next.
I decided to follow the line straight across the transom because I thought it would look nice and provide a little barrier between the aluminum and whatever I use for a transom pad.
Then three full coats of the aluminum etching primer.
For what I covered I did 3 coats and went through about 4 cans
Then it was onto the color topcoat again I went the Rustoleum pro in gloss red. From what I understand the pro stuff is much harder and more durable than the standard rattle cans and flows a little faster and evener. It seemed to do really good and I am pretty happy with the results.
so after all was said and done I did find a few flows but not enough to make it worth going over the whole thing again. All in all though not bad for my first ever time working with metal like this.
now onto the next steps, I am ordering some steelflex ultra slick to do the bottom below the chine, and the normal steel flex for the inside with the nonslip additive. In the week it will take to get here I hope to finish off the trailer since I am finally down far enough that I can start painting it. In between coats on Saturday I did both wheels. the local tire shop pulled the tires off for me for free since I trashed the valvestem trying to clean them up with the wire wheel on the angle grinder. Here is the before and after and after paint.
So the before after just one season in the salt, Chinese steel at its best.
and after some work with the angle grinder and wire wheel, down to clean metal ready for paint
now for some paint. I went with the Rustoleum cold galvanizing in the hopes that it really does provide "superior corrosion resistance" as it says on the can I figured for 5 bucks it was worth a try it can't be worse than the original paint. If it doesn't hold up I will just replace them with proper hot dip galvanized next year.
so hopefully tonight it will be more painting and new bunks so I have somewhere flip the boat onto so I can work on the inside.
