So on to the seats and transom install. I am getting near the end at this point and looking back it is clear that somewhere along the I completely misplaced my common sense and went full on nuts with this build. Don't get me wrong I had fun along the way and it gave me something to do but I could have done it a lot cheaper if I had a better plan from the beginning. Enough with the introspection and back to the fun bits so seat install...
the first step is to remember way back when what the seats and flotation looked like at the start
so yeah they were as much of a mess as everything else but they were still solid. It's not entirely clear but I think these might be the original pieces and once I pulled them apart they were clearly hand made at some point.
I cleaned them up and did the Rustoleum matching the outside then I attempted to get them lined up on the bottom of the seats. This was only mildly successful but unless someone gets a tape out it isn't noticeable they are a little off. I bolted them down with all 1/4 20 hardware that I tried to standardize on for everything on the boat. The hope is that will make it much easier later if I need to replace anything. I had drilled out the rivets so i could install them properly. I had visions of some really creative ways to put these back together but I just wimped out and went back to rivets as I had them and it worked for many years the first time around so why try to reinvent the wheel.
A bit of a montage there but you get the idea, line it up, drill the holes, install the angle, test fit and rivet the pod back on.
Then get the whole thing installed back in the hull.
I started in the middle as it pushed the hull out the most and then fit everything off of that.
again everything with the same stainless hardware.
Rinse and repeat for the second seat.
then onto fitting up the transom, I had to spend some quilty time with the belt sander to get this to all fit down nicely.
I got the corner caps to fit back on and they are back solid again.
I saw somewhere that you can use an old cutting board for a transom plate and as I was out of budget I got the wife to let me cut up an old one. so After some measuring, I got it cut up on the bandsaw.
it took some work but again some time on the belt sander got everything to fit. The total thickness was a little over 2 inches so after sanding I could just barely get the motor on but it works so I am fine with it.
So I have a few cleanup things to get it in the water.
1. get the bowring back in I really should have done that before spraying the bed liner but whatever
2. get the electrical installed and the lights mounted
3. adjust the trailer bunks and get the fenders reinstalled
4. fix the flat tire that developed while it was sitting
None of that is really critical with the exception of the bow eye as I don't have any way to keep it on the trailer and there is a big hole in the bow. I should be able to get all of that done fairly quickly though and with any luck, I will actually be fishing in the next few weeks.
