Got her out on the lake yesterday... little things, it’s always the little things and some big things. Going from a boat all set up and “complete” (my valco) to bare bones boat is quite a shocker as far as creature comforts go. Here’s the “must fix ASAP list”:
-leaks a bit of water right a the bow where I thought it would, also seems to be a small leak through the plug, will replace the plug hopefully that’ll fix it
-with no side guide bunks on the trailer, and the trailers short length this boat is serious pain to get trailered straight... especially with people waiting on you at the launch, felt like the boat launch noob all over again : /
-Having motor issues: When running with just myself in the boat, the throttle seemed weird. Basically a lot of random over revving, a couple times it overheated and died. The throttle seemed not very responsive and quite “sticky” when throttling up and down.
A couple things I think my issue might be, I’m hitting pockets of air and the prop is slipping, or the prop is maybe just slipping. But it all seemed to mostly go away with more and balanced weight in the boat. Or at least the over revving did.
I plan on installing a hydrofoil and doing a carb clean/rebuild and going from there. It idles kinda rough and will die if the throttle is all the way low. I will pickup a tiny tach knockoff also to observe my issues with a little more data behind them.
In other news, got the bow casting deck cut out, gonna make a couple passes through the router to make the edge look nice, then paint are spar urethane coats galore. Looking forward to being able to mount up my terrova again soon, it was sorely missed when trolling.
Slowly getting there, can’t wait to get to the more fun stuff, but useability and safety come first...
