1972 Mirrocraft 16' V aka "The bigger boat"
deadkitty said:
Framing just about complete. Next up to finish cutting up the decks for hatches and seat mounts, as well as build the console for all the electronics.
Hello- I see you removed the benches and doesn’t look like your putting them back in. With that framing you have, you expect the structure to be strong ? No flexing ? I’m at this stage and debating to either put the middle one back or do what you have done. I just don’t know if the boat will flex ... just looking for pointers/tips.
Thanks and great job !
Welp… right on schedule another two years and life and finally let me take another run at finishing her.
To answer the questions above:
I notched aluminum Angie and riveted to the existing structure. Layed it all flat and flush, filled the gaps with foam, layed a full sheet of sealed painted 15/32 plywood.
To answer the middle bench question, by adding all the cross beams and using angle in place connecting the center and sides I would say the sides flex way less than originally. Adding all the extra structure increased rigidity.
First up, finish the decking
I had a rough idea of what I wanted but the “economical” side of me and the perfectionist in me quarreled with how fancy I wanted to get. My wood working skills are just above passable so, imperfection will be called “custom” ;)
Back deck
Command center
The harder parts…
Then onto urethane coat
Did a motor check, good ole evinrude 25hp started right up , terrova working like a champ, fish finders still good to go…
Moving on to paint next
Wiring
Then install
Back deck
Command center
The harder parts…
Wiring
Then install
Like the "Custom" wood working
