Well done. You timed the fishing just about right, I hope.
deadkitty said:Attempted to install downrigger mounts... but after putting it all together I realized I didn’t leave enough clearance for the plastic mount to be able to slide and lock in, about 2cm short
deadkitty said:Lol LDUBS, these are the ones you were so awesome to send me [emoji2] I am even using the spacers you sent with because they do fit the profile almost perfectly. I checked the spacing using just the arm bar piece installed and drilled away, only to realize the plastic sleeve that connects it to the downrigger held it just high enough that I couldn’t lock it into place. I need to place the inner piece just a tad higher and I’ll be good to go as the trout and kokes start heading deeper into the water column. Thanks again for those mounts, once I get ‘em installed properly they will work great!
