I would love to be able to mess around in a nice metal shop. Dad has worked with wood since he was little, so we have an excellent wood setup, plus years of experience and tips to teach me, but metal was something new to us fairly recently. I have been teaching myself most everything I know about aluminum work, and he and I have been learning as we go with steel (he still won't let me touch his welder.
). I am also limited quite a bit in the tooling department. Even though I grew up around lotsa woodworking and carpentry, and am fairly fluent in that, I enjoy metal working a lot more.
Anyway, here is the next update.
Those aforementioned things connect to this.
That top bar is the one farthest to starboard in this picture.
Now, to answer y'all's question of why is the structure above the sheet. That will be my fully accessible wiring chase. The rod locker door will be right in front of that area, and that will have a cover, held on with stainless screws, into rivnuts that I will set into the square. That way, it is fully accessible, from the batteries, to the switch panel, and to each of the items that require power. Will make things easier down the road if I have to update/repair something.
My bow deck will extend to the back end of the longer battery box. Where those boxes are will be the approximate location of the batteries. The wiring chase will run across the top of the rod locker where that piece of copper pipe is.
Now, back here, I will have my switch panel. As you can see, there is a nice big opening, and with the top open, one can easily reach the back to service/repair it. And, there is ample room to organize all the wiring neatly. I have rested a piece of diamond plate in place to show the size of the opening, in the second picture.
Here is my first bonehead move of the day.
Remember that little gusset I had to strengthen the rod locker? Well, I forgot that I had to put a back on the rod locker. #-o The back will cover the back of the rod locker, and extend over in place of the gusset. Basically it will just be making the back of the locker, and the gusset one piece. I knew having that thing fit was too good to be true. #-o
