bonz_d
I haven't had the need or opportunity to use Gluvit yet though I know many that have and it's worked amazingly. I believe if you tighten up the bow area and then apply the Gluvit you'll be golden.
Yep whoever lost that anchor wasn't thinking straight for sure ! I have a use for the carabineer but wont be to hold the anchor for suresurfman said:I am surprised that carabineer clip holds that anchor, I wouldn't use it, the clip that is, okay for your keys on a belt loop.
Bigwrench said:I think I'm ready to seal and paint this hull !
Now some questions -
The wife and I have decided that we want to try Duralux Marine paint that can be purchased through several of our local hardware stores , at a price we can live with right now . Has anyone used this paint ?
The exact base color will be
Duck Boat Drab
Bigwrench said:I will be using Gluvit for the sealing process for sure. We are going to order 1 gallon. (8lbs)
Bigwrench said:I was thinking of using 3M 5200 for all of the through hull sealing of bolts and stuff like that but also found this locally at Home Depot (who also sells the Duralux)
I decided to do both sides just in case, have seen it done both ways so decided to just cover all baseslckstckn2smknbrls said:The sealer goes on the inside.
Wish I knew what it was like just to compare and give everyone a better idea but have never used it. This Coat It seems to to be pretty tough though. Hopefully it will hold over time, I will definitely post updateslckstckn2smknbrls said:Sounds like it's more like steelflex.
