Ok so had a couple hours tonight and decided I absolutely had to make some progress on this thing !
I should point out that during the Mercury build the tin rig was outside covered with TWO boat covers and still somehow took on water , was pointed bow down and there was like 2-3 foot of water in it ! Good thing was it did not leak a drop anywhere so this thing is sealed up really good ! Bad news is I had to really clean everything up again and wash it all down ! Rusted up a lot of stuff and all my cardboard templates were
Ruined
but that's ok cause I got a running Merc lol
Right now I can't spend any more money but I have a lot of stuff already here and ready to go so I started working on things that I can do and put the stuff off that's gonna cost me more money (Front Deck Welding)!
Started out taking measurements of my back deck area, it is one flat sheet and relatively easy to cut so I cleaned up everything and got to work
Laid one edge in square and marked the height of the deck against the sides. I should also note that with all the decking out of the boat the sides sorta spread apart so I had to account for that. Once the piece is cut square I will fasten one side and then pull the other side up tight with a ratchet strap to make sure the rear sides of the boat are square with the transom.
I had trouble keeping the jig saw cutting straight because the little blade has a tendency to walk or bend easily so I tried to leave a sharpie marker tip width for my cut line tried using a 2x4 as a guide . It worked ok but I think for long straight cuts I will use a skill saw and have a helper spraying lubricant.
The cut wasn't as nice as I wanted it but here's where I got creative and using the piece I cut off I flipped it so the factory edge was even with my mark , clamped it to it and filed, sanded and ground it flush until I had an almost perfect cut
Close up
Using several power tools
It took a little more time and effort but I'm happy with this piece
Installed
I'll get the splash well area cut out next and the start working on locker cut outs.
