dearl
Getting closer..... Got the front livewell fittings in, recirculation pump in, and all the plumbing done for the livewell. If I never work with 5200 again it will be to soon. I guess the cold weather has it to hard to work with, but this stuff will get anywhere, and everywhere. I'm glad I'm bald, or I might be getting a bikini wax on my head. :LOL2: I had to pull the lower livewell drain thru hull fitting, I planned to run all 3/4" lines and fittings, but I failed to think about the drain line is made for a 1 1/8th hose. Sooo I have to figure out how to get a 3/4" fitting that is made for a 1 3/8" hole. I have seen thru hulls made to fit a 1 1/8th hole, do any of you think that will be to much play if tightened good and seated in 5200? I have that line and the bilge pump, and I'm done with the plumbing, Next wiring!
