dearl
Ambitious build....I like it. Now that the slate is clean its easier to visualize what you want. Lots of room in that little boat, options are endless. Keep weight balance in mind during the design.
dearl said:Ambitious build....I like it. Now that the slate is clean its easier to visualize what you want. Lots of room in that little boat, options are endless. Keep weight balance in mind during the design.
dearl said:Even at 20 Hp that's not a lot of horsepower to lift and hold a lot of weight, keep in mind a motor has to lift and hold nose weight in order to plane the hull. If it cant you get what's called porposing. The nose will raise and lower on its on at speed trying to plane. Keep your heaviest weight in the stern, mid weight center, and lighter stuff in the bow. You can get away with some heavier stuff in the bow, a battery or fuel tank, but not much over that.
dearl said:Nice progress...One word of caution, if you are dead set on sealing it with fiberglass use epoxy resin. It will cost more up front, but if this is a boat you will have for a long time, use epoxy resin not polyester.
Your plan for the sub-floor sounds like a good one, keep in mind your stringers will all be different lengths and widths, a lot of measuring and double checking before you start cutting, just saying things can get out of whack quick with V-hull stringers.
Foam.....just make sure the channels for the water to drain out the hull are open, and you don't foam yourself into a corner. You can set up a pretty nasty corrosion situation by not allowing the hull to drain. Im dealing with that very thing on my build, its no fun repairing either, very time consuming.
