floridabrahmer said:I have the same boat just starting to rebuild it, but i gutted mine out completely. The foam in these boats gets very heavy when it starts soaking up the water so I did away with all of it.
srreynolds2003 said:floridabrahmer said:I have the same boat just starting to rebuild it, but i gutted mine out completely. The foam in these boats gets very heavy when it starts soaking up the water so I did away with all of it.
Do you need foam in these boats?
I'm getting ready to start a rebuild on my dads old bass tracker and was thinking I could use that space as storage.
rusty503 said:Actually i would recommend using urethane expanding closed cell pourable foam. Being closed cell, it will not absorb water. It is available in different weights. The lightest is 2 lb. That means a cubic foot weighs 2 pounds. It is also the most buoyant.
Sent from my SAMSUNG-SM-G920A using Tapatalk
BYOB Fishing said:I wonder what the buoyancy factor of a sealed up bucket vs a block of foam the same size would be?? Or maybe just pour in a bunch of ping pong balls...hahahaha
