riverbud55
-CN- said:I am not a welder and want it to be as simple as using a few bolts.
Also, my main reason for needing the tongue extension is for weight distributing purposes. I need to move the boat further forward on the trailer as I have added a gas outboard (which I never originally planned to do), and with the already compact trailer, the boat is already as far forward as I will comfortably go without the nose being too close to my vehicle.
I think I'm gonna start looking into just getting a new trailer, but my budget is under $100 for this project and that won't even buy a fixer-upper.
mite be able to get a piece of 2x2x3/16 tube steel long enough for your needs and use U bolts to hold/bolt it under the existing tube,,, mite be best to look in to the cost to have a weld shop cut and remove the old tube and replace it with a 2x3x3/16 tube, 100$ would come real close to getting done in our shop,, if ya lived a little closer do it for a six pack of ice tea,,, ok Ill take ''a'' bud lite,,,one thing could save you is get the steel bought take home pre drill the end for a new coupler and any other hole you mite need, probably going to need to add safety chains some how whether bolted or welded
post a pic of what ya have to work with
