Extremely frustrated.
Put the boat in the water for what I thought was a final leak check and the transom seams (where the aft side is riveted to the sides/bottom) are still weeping. Probably need to seal the outside of the seams since there are hundreds of rivets to replace (they're covered by a rib so I can't see which rivets actually leak). I wanted to keep the original look of the boat and not mar it with JB WELD and sanding, but I don't know of any other options. Saw an informertial on Alumaloy (https://www.alumaloy.com/) and was mesmorized, but don't know if it's legitimate. Wanted to avoid painting the entire inside (I agree with Kismet's earlier post). Any thoughts? Most of the weepage was fixed, but there's enough (~6oz/hr) that I'd like to fix it permanently.
Also did a stability check and the boat was pretty wobbly when I walked around on the bench seats. I had hoped to put in a front and rear casting deck, but I don't know anymore. The boat was completely bare and empty (no motor, only me), so I'm not sure if that would add to the stability. If I don't put a casting deck, then it seems like a waste to put in a bow mounted trolling motor, since I'd probably fish from the center. the boat is 54" wide and the seats are 18" from the bottom with 6" of gunwhale over the seats.
One thing to note was the boat only drafted about 1" with me in it and about 1/2" empty according to the guy that works at the base marina that was watching.
Please tinbooat brothers and sisters, you're thoughts on these issues would be appreciated. I did see some other Model F mods, but none had a casting deck that I noticed. Maybe this is the reason.
