Surprising when you look online at what prop is recommended for your motor.....nothing in the manual, nothing online.
Right now I have 10 1/4 x 13. When I first got the boat I was running 33 top end....now I'm down to 29-31 just depending on wind.
After the initial break in period it dropped to 31.....after I beat up my prop a bit, it's around 29-31.....
Looking to get a bit more top end. There really is nothing to rely on as every boat is different and every boat is loaded different.
I'm considering an 11x15 Stainless. Found a good deal on an off brand with decent reviews. I have to determine clearance first to see if an 11 will even fit. I'm assuming a 15 will get me a little more top end and the extra diameter will keep RPM's down to give a bit more power for a heavier jon boat.
