Country Dave
Badbagger said:"Clueless" - Moving on, my seats came in today and here's a crappy cell phone pic. Planning on mounts for my Garmin GPSMAP 720S and presently price shopping on the Lowrance HDS GEN2 12 Touch. Garmin will be my primary GPS and the Lowrance used for down and side imaging. Called the fabricator too late on Friday so I've got to wait for Monday for an update and pickup time. Etec gets pulled Wednesday and I'll start to prep the beast for Linex the following Wednesday which will take a week. Should be picking up the trolling motor soon. Since these electronics are so damn sensitive I'm rethinking electrical and will probably end up with 4 batteries. One dedicated for starting only, two house batteries for the trolling motor and bilge pump and misc other things and then a 4th house battery strictly for the Garmin and Lowrance units. Going to be battery heavy :shock:
I had 4 batters on my 17 MAKO center console but it was overkill. You need to have 2 deep cycle batteries for your trolling motor because it’s a 24 volt system. Those have to be standalone because you’re going to connect them in series so you have 24 volts. You don’t want to run anything else but the trolling motor off of them. The other 2 batteries should be on a switch. Don’t separate them. Run everything to and from a busbar.
