Country Dave
Badbagger said:Thanks Dave, when I get in from work I'll do some checking and more reading. Local board members also HIGHLY recommend one. Boat is NOT a tunnel but folks at Bob's still recommend one.
BB
Good morning bro,
It would be almost pointless to have a tunnel and not get the motor up, but that doesn’t mean a non tunnel hull can’t benefit from a jack plate. A tunnel hull will let you run shallower than a conventional fiberglass flats boat but it doesn’t necessarily float any shallower. That’s why so many of us our going to the tins because first and foremost they are so much lighter than there fiberglass counterparts. Therefore they float and run shallower. The other benefit of a tunnel is it lets you get the boat up on plane in shallower water because the tunnel allows water to free flow back to the motor; in fact it helps funnel the water back and pushes it upwards so the prop can have something to bite.
Tunnel hulls are bad ass for skinny water but a non tunnel flat bottom tin or a mod V tin with just a little bit of deadrise will outperform most fiberglass tunnels everyday of the week and twice on Sunday, but we need to still get the motor up. If there is any downside to a jack plate it would be a reduction in water flow for the cooling system. You just have to watch the pisser/telltale and make sure it’s spraying.
Some guys have the lower unit modified for a low water pick up, it really depends on how shallow you run. I was running my 1448 in about 6 inches of water. I’m going to see how the 1752 does. I might let Bob’s do my low water pic up. Another $600 Hey its only money. :LOL2:
