Nativeduckhunter
- Joined
- May 19, 2016
- Messages
- Reaction score
- 0
Just wondering if I should add a loop to hook my boat winch to or use the front handle.
It's tracker 1542
It's tracker 1542
fishmonger said:Handles are not made for winching. It would be wise to add a ubolt and reinforce the hull where the ubolt is going through. I use wood scraps cut to about 3"x4"(or what ever size fits) then fender washers, regular flat washers, and nylon lock nuts. The force exerted by the winch needs to be spread out over a larger area.
I used large stainless steel fender washers.Nativeduckhunter said:Thanks did u reinforce it or anything
