Bubba
So the inside of my fenders on my trailer are carpeted. On one side the plywood is completely detroyed and busted up and I just pulled it out the other day because it was getting down into my tire/wheel. So I need to replace this, although i'm not sure what the best way is. It had rivets around the edge holding it on, is this the way I need to re-do it? Or is there an easier way because I don't have a rivet gun, and they look like pretty good size rivets(the shaft on them is at least 1/8" in diameter).
Also, What do I need to get as far as wood...just regular plywood and coat it with some waterproofer and then re-cover with carpet?
Any tips would be great. Thanks!
