Don't mention to hijack but I have been researching and there are a ton of diy projects for a shallow water anchor. But I have not seen anyone using T-Post. I have a 12ft Lowe V-hull that has a set of handles on the transom and I was thinking of running a 7ft t-post through each of the handles (if necessary). I would grind one end into a spike and drill holes in the post to add attachment rings as required. Besides the additional weight is there any other disadvantage? Do you think this would work for rocky bottom?
