Well I finished all that I'm going to do to my boat for now. Just need the motor and then I'm off fishing. I'll tackle the fish finder, electrical and livewell at a later date as well as the flooring. I posted this in another members thread but thought it deserved to be here too. I had to remount my onboard charger due to it making contact with the hull. I'm not found of putting wood in my boat seeing it doesn't have any and something about a cutting board doesn't sit right either. I went with my idea of the nylon car clips and drilled square holes. Believe it or not, it was a breeze and cost under $5. Here is what I did.
Supplies used. Clips were bought at Lowes. They have a 1/4" lip. Stainless steel screws I had already.
1st I drilled 3/8" holes and then just squared some corners with this Dremel tool bit.
Test fit on a scrap piece of aluminum.
Boda-bing, boda-boom and finished product. Took all of 10 minutes.
I also finally ran the wires for my trolling motor plug and hooked up the onboard charger. Not much to see as the trolling battery and onboard charger are crammed under the casting deck and not being able to take a picture. Trolling motor worked and was really quiet.
Thanks for looking.
Thanks for looking.
