Finally got back on the water
Attwanl
Lake George FL
Hi
Finally got my boat back on the water.... I took it this winter and worked it over, due to events beyond my control I didn't get to work on it much. So it has taken me until now to get it back on the water
It had some water creeping around some rivets, so I rebuked them all. Then cleaned it up and repainted the outside with 2 part epoxy paint. I did the inside with just rustolem oil base( didn't have enough epoxy). Got some seats too.
I all so worked on the trailer too, new bunk boards and brackets, new brace across the back and little work here and there on it.
I did some work for trade on a nissan 9.8hp 4-stroke, but it is a long shaft, so I made a quickie jack plate. It is only temporary. Before you guys start busting on me on my jacked up jack plate.....haha.......just to see if it was going to work, maybe a little excited about getting a new motor too. I was a little worried about the extra weight of the 4-stroke.
But it worked out great and I'm happy with the way it ran, no leaks too.
I will make a better jake plate now off the designs I got from here.
All in all a good day. Just thought I'd share it
    736.7 KB
    252.6 KB
    193.7 KB
Congrats on getting back on the water. Glad to see ya worked something out with the outboard too although from the pictures that looks like more than just a 5 inch jack plate, it looks like at least 10 inches which would mean it is a extra long shaft. My understanding is short 15" - long 20" - extra long 25".
Tim
It is actually a 6" rise on the transom..... I know the picture looks like it's way up there. The serial numbers say 20" shaft. But to get the cavitation plate level with the bottom, I had to make the transom 22". I measured from the cavitation plate to where it hangs on the boat.
Does any one know how far can one go down before losing efficiency?
