flatbotm's 1542 build
I went to the aluminum recycling place this afternoon and the closest thing I could find was a 5 foot piece of 3*5" 3/8 thick angle and a 3 footer of 5" 3/8 flat so that is what I'm building it out of. Cost was $48. 1/4 the price of a hd jack plate.
So I was wrong the angle was 1/4 and the flat stock was 3/8 woops! Oh well I Improvised. Here are the pics of the jack plate thus far. Its 5 inches of stand off and Initially it will have 5 inches of vertical rise but will be adjustable.
that looks great
How do you plan to make it adjustable? Are you going to slot the holes or just stagger them.
Great looking jackplate. Now mine does not look like just about every other homemade job :?
=D> =D> =D>
Thanks guys. Derek I'd planned to just stagger the holes because I don't have access to a mill to slot them. Ive slotted holes manually before but its a pain. How finite adjustment do I need?
The finite adjustment is the reason to slot them. Most people adjust them in increments of 1/2" anyway, so you should be fine with that spacing.
Cool I'll just go with the 1/2 spacing then. For the initial run how high should I jack the motor. Cav plate even or 1/2 inch up? Also what size bolts and how many for bolting to the transom? Any Special silicone?
Flatbotm, this is the best sealant I have ever used on transom fasteners and on any thing to seal out water, it is polyurethane and it turns to a tough rubber like compund when dry (takes about 3 days to fully cure). Warning, wear gloves or you will have to wear it off of your hands!
Thanks MMF! I'm going to go pick up some locktite. Do you guys think (4) 1/2 bolts would be enough to hold the transom to the boat?
Are you meaning the jack plate? If so, 4 might get it but I would use 6 to be on the safe side......PS, on that Loctite PL adhesive, make sure it is the "roof and flashing" sealer.....good luck and watchin your build..... 8)
What I meant to ask was do you think (4) 1/2 bolts will be enough to hold the jackplate to the transom? Sometimes I post with my phone and it is easy to make typos. I want to make as few holes as possible in the transom.
probably so, my 150 HP Mercury only has 4 SS- 1/2" bolts holding it to the transom, as a matter of fact, all my motors have 4 SS- 1/2" bolts going thru transom.......
I was hoping 4 would be enough because I allready bought 4 and they were $4.00 each. My local true value didn't have the right locktite stuff so I'm going to try home depot today.
I used my little bending break to make a bracket for the controls yesterday.
Tonight I finished drilling all the holes in the jack plate. I picked up the locktite pl stuff. Do you guys with homemade jack plates mount a piece of wood where the motor clamps? I will be drilling the transom and mounting the jack plate in the morning and I was wondering if I should mount some wood or sandwich some wood in aluminum like the transom?
So I didn't get completely done this weekend as planned but I did completely finish the jackplate and it is in place and ready to drill and mount. I used a piece of Brazilian walnut for the motor mount clamps ( i am going to bolt it as well). I used some linseed oil to treat the wood. I counter sunk the stainless screws holding the (ipe) Brazilian walnut to the jack plate. I have stainless 3/8 bolts for the jack plate as well as 1/2 stainless to bolt it to the transom. Here's the pics.
I am getting ready to hang the new motor and Im trying to decide where to set the jack plate up for the first run. Setting it at 5 inches of raise the bottom of the drain plug is right at 20". The bottom of the rest of the boat is 19.25 or so. I know the cavitation plate should be even with the bottom of the boat but is that refering to the lowest point? Here is the bottom of the boat so you can see what Im asking.
flatbotm, it's the flat part of the boat, don't count the tube....PS, if you experiment with motor height for better speed, don't get too high and starve the water pump from water without a low water pickup, it will make fast history of your motor!
