water bouy said:Thanks kindly. While i was at Lowes I checked out their carpet with the rubber backing. Anybody recommend it? I got a couple more runners done today and decided it needs a casting deck at bench level after all. It'll have plenty of room underneath for a battery and whatnots and if I find it sits too high it'll be easy to take off.
oakchas said:water bouy said:Thanks kindly. While i was at Lowes I checked out their carpet with the rubber backing. Anybody recommend it? I got a couple more runners done today and decided it needs a casting deck at bench level after all. It'll have plenty of room underneath for a battery and whatnots and if I find it sits too high it'll be easy to take off.
Store 2611, Omaha NE here!
I work at Lowe's... I went to boatcarpet.com. for my boat carpet.
The face weight on Lowe's carpet is lower than 16 oz.; at least what's available in our store.
I also purchased boat carpet padding from another source, bassboatseats.com... Just to cover the areas where the most traffic will be.
water bouy said:Until today my plan was to rivet angle along each side and then to the planks so I can put an aisle through the middle bench but now I'm not so sure it needs all that. If the middle bench is braced with angle to planks running under it, it looks like it would have as much support as it needs? And then no need to penetrate the outside.
