yest. i just got 2 weights and a 7 inch pedestal for the bak bench of my boat. but the prob. is that i want this.... but i have 15lb weights.
Anchormate
Anchormate
Wait, your mom bought the boat for you, and you got the car for your birthday? I take it you don't have to work for your toys.....tompatt said:its like a piece of plywood the owner before had on it. im guessing he had one on before then took them off, but im gonna take it off. i dont like it. im gonna try and make a plan for the front deck and then put on my TM. the plywood is like drilled into the top of the boat. i cant take any pics of my boat till about fri or so. im in KY and my boat is bak home in GA. i can tell u some about the boat.... we got it from one of my mom's friend's dad. he was old. it was too small for him and his family to use. so the boat had been out like 3 times. the engine is like a 10 yr. old johnson 6 hp motor. and the boat and the trailer are brand new. My mom got it for about $800. It came with all the stuff it has on it now. Im not goin to do anything to the boat first.. until i aleast take it out once and get a feel for the boat. I think ill mount the trolling motor on the front rightside of the boat. today i think im goin with my grandpa to go get a Battery Charger for the boat battery... once i get one.
bassboy1 said:Wait, your mom bought the boat for you, and you got the car for your birthday? I take it you don't have to work for your toys.....tompatt said:its like a piece of plywood the owner before had on it. im guessing he had one on before then took them off, but im gonna take it off. i dont like it. im gonna try and make a plan for the front deck and then put on my TM. the plywood is like drilled into the top of the boat. i cant take any pics of my boat till about fri or so. im in KY and my boat is bak home in GA. i can tell u some about the boat.... we got it from one of my mom's friend's dad. he was old. it was too small for him and his family to use. so the boat had been out like 3 times. the engine is like a 10 yr. old johnson 6 hp motor. and the boat and the trailer are brand new. My mom got it for about $800. It came with all the stuff it has on it now. Im not goin to do anything to the boat first.. until i aleast take it out once and get a feel for the boat. I think ill mount the trolling motor on the front rightside of the boat. today i think im goin with my grandpa to go get a Battery Charger for the boat battery... once i get one.
Your engine age estimate is WAY off. It is more like 35 years old. Give me the model number (located on the left side of the transom clamp) and I can tell you the exact year. I love the OMC twins. Especially in the under 25 or 30 horse range, they will run forever and then some. The mid to late 70s are great years to own, as a workhorse, as they are new enough to have modern desirable features, but old enough that they don't have all the special electronics and other parts that limit an engines age to less than 20 years.
bAcKpAiN said:The thing that comes to mind off the bat is to go lighter on the lumber. You really don't want 4x4's in your boat. I have seen some use 2x4's, I used 2x3's because of availability, but in reality 2x2's are brobably the best option in a boat.
Jim said:I love the plans!![]()
Jim said:From what I have seen from the other mods done by the other guys, I think its fine..Don't hold me to it though.
Naw, 3/4 is too big and heavy. I would go with 1/2, and I believe pbw used 3/8 on his. Check his thread, and see what his structure spacing is. As for the type, don't get pressure treated. It is heavy, and more importantly, corrosive to aluminum. I don't know how familiar you are with plywood, but at your average home improvement store, they will have a couple types. One is sheathing, which will have a fairly good side, but usually the backside will be knarly. Another is furniture grade (probably not the right name, but that is what it is commonly used for). It has 2 clean sides, usually with footballs in the voids. That is probably what you want. Sometimes, you can find a pallet of sheathing that came from a good set of trees, so the backside doesn't have many knots or voids. If you find this, it will save you a few bucks.tompatt said:Jim said:From what I have seen from the other mods done by the other guys, I think its fine..Don't hold me to it though.
LOL. what kind of plywood should i use.... im gonna deck the front, then lay a floor across the middle. 3/4 for all of it?
bassboy1 said:Naw, 3/4 is too big and heavy. I would go with 1/2, and I believe pbw used 3/8 on his. Check his thread, and see what his structure spacing is. As for the type, don't get pressure treated. It is heavy, and more importantly, corrosive to aluminum. I don't know how familiar you are with plywood, but at your average home improvement store, they will have a couple types. One is sheathing, which will have a fairly good side, but usually the backside will be knarly. Another is furniture grade (probably not the right name, but that is what it is commonly used for). It has 2 clean sides, usually with footballs in the voids. That is probably what you want. Sometimes, you can find a pallet of sheathing that came from a good set of trees, so the backside doesn't have many knots or voids. If you find this, it will save you a few bucks.tompatt said:Jim said:From what I have seen from the other mods done by the other guys, I think its fine..Don't hold me to it though.
Read the last sentence of my previous post.tompatt said:shouldnt i need a water sealer?
bassboy1 said:Read the last sentence of my previous post.tompatt said:shouldnt i need a water sealer?
Stainless. Putting regular steel screws in a boat will make the future owner hate you forever. Trust me on that one.tompatt said:also wat kind of screws do i need to use to connect the deck? anything special?
bassboy1 said:Stainless. Putting regular steel screws in a boat will make the future owner hate you forever. Trust me on that one.tompatt said:also wat kind of screws do i need to use to connect the deck? anything special?
