Shoedawg
Thanks. It all those years of military training that's been beaten into my head. Details, details, details.
Androsyn said:Man,
That is one sweet boat you got there and it's up on a kick-ass trailer too. Keep up the good work. You're inspiring me to go out and buy a bigger boat for my next project. I've never played with fiberglass so all those uploads are very cool and informative. I can't wait to see this thing in the water!
Shoedawg said:Been a few weeks, but I am making some progress on the build. Had the mother-in-law in town for a week and had to burn up two days to take a trip to Wyoming, so I didn't get a whole lot done. Here's what has been going on though.
Started tackling the bow deck and casting deck. I started off making a template for the bow deck. Used some cardboard and traced the outline of the bow, underneath, using a Sharpie.
Heres the template. Used a straight edge to fix the outline up a bit.
After that I cut the template out and transcribed it to my aluminum sheet.
Here she is all cut out. It's an OK fit. I used my Jig-Saw to cut it out. Have a little bit of a gap up front, but I plan on fixing that with some scrap sheet I have left. Plus it's going to be covered with Hydroturf, so not really concerned about it.
Next up was cutting the casting deck. This was a PIA to get right and fit. I ran some thin cardboard over the area I wanted the casting deck to be and did my best to trace the area. The boat tapers toward the front, so trying to get a close template was challenging. I used some clamps and did the best I could to stretch out the cardboard.
Here's the template on the sheet and ready to be cut. Little did I know, I would be pulling the casting deck in and out of the boat and returning to the cutting station about a BILLION times. :roll: :roll: :roll:
The problem I was running into with the casting deck was that it keep catching on the inside hull, right below the rail. It was rubbing against the hull and not fully flush with the support brackets underneath the deck. I finally got it to fit after using my angle grinder with a Flap Disk on it. Took some time going back and forth, but it finally went in nicely. It did scratch the piss out of my paint, but I knew it would. Got to retouch up with paint anyway. Have some areas around the top of the boat and rails that need it.
Big_ug_chevy said:Clean build bro, that aluminum plate was a hug pain in the ass for me too, but it was well worth the back and forth to get it right. Are you sticking with the side consol or going center console?
