Filled all The screw holes in the transom from various depth finders with liberal amounts of 5200 and stainless screws. Also plugged up the few little corrosion holes in the transom with 5200 as well. I then put some self etching primer on the boat. Felt good to make it green instead of red. :twisted:
Looks great all gutted, now for the fun part of putting it all back together! I like that hull, wish my little 14' boat was that well engineered from the factory.
No, red was original. I am going to either do a khaki type color or a camouflage pattern. Thanks man! Your build is looking good. Those are some pig walleye in your pic.
Coat one is on. Etching primer was finished this afternoon, after church. I am brushing, and plan to use one or two aerosol cans to smooth things out if they need help after coat two. I am using hunters specialties marsh grass as my base coat. This stuff is really really thick. I used it on my first duck boat with good success as far as wear is concerned. Once the second coat is dry I will leak test and hopefully things are in good shape. I have plenty of 5200 and plan to use it. Preventatively.
Click on the pics and they flip to correct side up. Not sure why the iPad posts them that way.
