And finally, my floor. First let me say that what I wanted was a lightweight, durable, nonslip floor, and I didnt want to feel the ribs on my feet through it. I also wanted to keep the floor as low as possible. To get a level floor, I would have had to raise the floor 4". That was not ideal, so a frame and as out. I was going to use a 3/4" rubber stall mat, which would have conformed to the curve of the boat and strong enough to hide the feel of the ribs. However, when I went to see the mat,it weighed 90lbs, and Id need 2, so thats like an extra persons weight in floor mats!
Well after much research and store visits, I came up with the soljtion. Very lightweight,sturdy, comfortable and easy to remove for cleaning and drying out the hull. I found a 5/8" closed cell commercial grade antifatigue mat designed to be non slip. Its like the consistency of memory foam, so not squishy like a sponge,but like its viscous slow squishy. Alone, it fits perfectly and is heavy enough that it wont move or blow away.Alone, when I step on it,it greatly reduces the feeling of the ribs, but that gave me an idea....
I bought 1/2" polystyrene insulation board (non absorbent) and I cut it and laid it in between the ribs. When I overlayed mat,it basically gave support enough to make the ribs not felt at all! And since its so easy to remove, any water that may be trapped after a day on the lake can be easily drained/cleaned afterwards. The foam is thin enough to concorm to the curve of the hull,yet it strong and doesnt get squished, especially with the mat on top.
The mat has a great look to it, complete with grooves and subtle yet effctive textured surface. I sprayed it wet andtried it with shoes and barefeet and sandals and its absolutely noslip.
Hello, I sent you a PM as I would like to know where you bought that mat for your floors, very cool, they look great and thats the color I need
