WPS
Something I forgot to tell ya... On the inside of some tubing is a weld (Flash)... That will keep some tubing from going inside the other, I've had to remove the weld flash 1' back just to get tubing to fit inside the other, and its not fun!Y_J said:The extra piece of 2 1/2" tubing he gave me was 3' 6" long but now that you mention it, 6" slid inside the 3" tubing just isn't enough.
I know most trailer tongues are 1/8", and I've seen some 1/16" thick.... I looked at your picture and it looks like the tubing the PO gave you is 1/8".
Did you take the coupler off yet ?... Take the 2-1/2" and see how it fits inside the 3" tubing, and take a pic if you can.... That will help a lot to let me see what you have!
Since the boat won't weigh all that much, you could probably just slide the tubing 6" inside the other... It would be fine after its welded all the way around.
Is that Jet Ski trailer ''galvanized'' ?... If it is, be careful welding on it.. (read about it)!
The tubing he gave you is probably 1/4", and the tubing on the trailer is probably 1/8" thick.Y_J said:The only thing I don't like about the extra piece is that the walls are twice as thick as the 3" tubing and that thing has to weigh about 40 lb (rough guess).
You might be better off trying to fine the same thickness somewhere if you can!
