Yup. I was looking at that a few days ago. I'm going to raise the wench up 2 more notches and see how that works out.Va Larry said:Trailers looking good, but the winch looks a little low.
A straighter pull on the bow eye would make it easier to crank it that last foot or so to get the bow firmly against the bow stop.
Thank you. I'll have to play with it to see if it can work out with the wench on top. I need to work on the bow stop bars anyway. They seem to be off kilter to the side a bit.OutrageGIS said:Looks great, nice job with the welding! I also think the winch looks low, might put the winch on top and the v block under? Might not matter if you keep the boat light, but should make loading a bit easier.
Thanks so much. It had been years since I had done any welding so I was a bit worried about how well it would hold up. After I was done I did a drop test on it. :shock: I picked it up almost chest high and dropped it a couple of times then searched for any stress cracks in the weld. None could be found so she should hold up pretty good.WPS said:Y_J,..Nice job extending the trailer tongue!... You turned that jet ski trailer into a nice trailer for your boat!.. Great job! :mrgreen:
I got my trailer tongue extended, and I had to (like you), so I would have room for my jack and spare tire... Looks like you will have plenty of room when you have the trailer hooked up to your truck!
Keep up the good work!... Trailer will look nice when you get it painted!
Thanks, and Thanks for the tip, WPS. I sure wanted to put on that second coat today. But the weather just wouldn't cooperate. Maybe tomorrow, I hope.WPS said:Nice job, Y_J... Trailer looks great!
A long time ago, I made some fenders out of an old aluminum road sign... I went to the state road garage, and they gave me an old sign.
I don't have any pictures of the fenders, that was back in 93 when I made them... I cut 2 square pieces (maybe 2'x2').. Then marked where I wanted to bolt the fender to the frame. (on top).... Then used a saw and made a cut on ''each side''... Then put the aluminum in a vise and bent the aluminum into the shape that I wanted... (Kind of hard to explain)Y_J said:Thanks, and Thanks for the tip, WPS. I sure wanted to put on that second coat today. But the weather just wouldn't cooperate. Maybe tomorrow, I hope.WPS said:Nice job, Y_J... Trailer looks great!
I also decided yesterday that I was going to get a couple cans of the metalic chrome paint and paint the wheeles with it. Got to put a stop to the rust that's showing up on them.
Not as yet. Next payday I'll get the chrome paint. I've got a couple cans of Rust Oleum self etching primer left over from the trailer to use on the wheeles. Then it's also time to start primering the boat itself. Started back to grinding out the paint on the inside of the boat today. Slowly I turn, step by step...WPS said:Y_J said:Did you use ''Rustoleum self etching primer'' on your rims first ?... That should stop the rust!... Also, try and use a brush on a drill to get some of the rust off!... I hate trying to remove rust from rims and hate painting rims.WPS said:Nice job, Y_J... Trailer looks great!
A 55 gal' plastic drum would work too... I've seen guys make fenders out of them to cover the front tires on tractors.Y_J said:The trailer is ready for its inspection other than the fenders. A sheriff deputy told me that law mandates that trailers must have fenders in Georgia. As soon as I get me a 55 gal. Metal drum, that problem will be solved.
Take a hammer and hit near the end of it.Y_J said:Now if I can just figure out a way to get the old bearing protectors off. Any suggestions here?
Thank you very much. Also got one problem taken care of today. Got the nut onto the crankshaft. Wooot. Fiddled with it again this morning and got ticked off at it. Threw the motor in the back of my truck and took it to West Georgia Marine. Asked them what they would charge me to run a die down the threads to clean it up. They took care of it and didn't charge me anything. Now I can finish putting the motor back together.OutrageGIS said:Lookin good YJ! Very clean setup on the trailer!
I was trying the hammer thing yesterday and they wouldn't budge. Guess maybe I was afraid to hit them to hard. Will give it another go round tomorrow.WPS said:Trailer looks good!... You done a great job on it!
