G Flex and Epoxy(Coat it, 8Lbs/80sqft) will be here Friday. Going to fix the obvious areas, dbl check a few more and try and coat as much as I can. Will either do all seams/rivets first and then start in the back and cover as much as I can get covered. Since the very back bottom is the most beat up part.
May pick up my transom wood on way home tonight. But dont want to leave it sitting until the weekend so may wait til I'm done sealing then go grab a sheet (and some varnish). Can I stain the transom to match the seats then seal em up with spar? Or would it be better to seal em up then paint them whatever color I want?
