jdbassin2003
That paint Job is amazing, Getting ready to start my own project, So many ideas on here
fish2keel said:handiman,
Great boat! I have followed this thread and read it over several times!
I have a few questions. You said when you were painting your motor you used red putty....do you have the name of this stuff? I have some dings in my motor and want to fill them. Your motor is amazing as with the rest of the boat! Also what was your procedure on painting the motor? I saw you said you wet sanded but did you sand, paint, wet sand and paint again. Just curious. I hope to have my motor half as nice as yours!
Ill keep following along! Thanks in advance
Sometimes it's those "Eureka Moments" that yield some of the really clever solutions that make life so easy. Beautiful work! =D>270Handiman said:One of my best ideas was creating the small fitting block you see in the bottom left hand corner of this pic. It is just a piece of my deck tubing with a small piece of scrap floor plate attached to it. I used this to position the piece of angle that is attached to the rear of the existing deck. By holding it up flush with the existing deck, I could just slide the angle up below it and drill my holes. The top edge of the existing deck is rounded over, so there was a small bit of overlap in the way the new deck would attach, and make the tightest joint possible. I also used it on the top of the bulkhead in the back to determine what height to cut everything back there to have a perfectly flat surface from the front of the original deck to the back of the new extension.
Howard said:Very nice! Love that you left it opened without to much decking. Why did you not rivet the floor to the ribs?
