MrSimon
That looks really good. Much better than leaving it bare aluminum.
Personally, I would do that all out of the boat so it's easier to get to your board ends. Also, about your leveling question as long as it is fairly level you should be ok. Screwing down your decking will tighten everything up but as close to level as possible is ideal. Wood tolerances are much easier to work with than metal so you have an advantage there.enielsen said:If every single board isn't exactly level to the nearest degree with the other boards will it be ok? Also, should I take my decks out and stain/waterproof them or just leave them in the boat and do it?
