danmyersmn
The way I have seen them done in the past is to cut like an X that you suggested but instead of just the X doing more then just two cuts. Kind of like cutting a pizza I suppose. I would guess a seat post hole maybe 4-5 cuts should be enough, then just wrap them over the edge and glue down. Maybe throw a stable or two in to hold until the glue sets then pull the staples back out.
The downside to doing that is that you need to cut a bigger hole to fit the carpet. Since the carpet is going to be under the seat base the seat base would keep it from fraying and coming back up and the screws/toggles holding the base down will also help keep the carpet from pulling away from the hole. I might just cut use some good strong glue around the hole and glue it down. Once the glue is set then cut it around the hole.
