I'm pretty much done as of today! There are a few little things I'll be doing, but I could hit the water tomorrow if I wasn't working.
Here's a summary of what I did this weekend to finish up. First thing yesterday morning, I took the boat to a local welder, and he sealed off the hole that goes to the small livewell that I won't be using. That gives me a lot of peace of mind that I had it done right instead of using some type of band-aid method. The livewell is under my deck and not being used, and I hated the idea of something failing and not knowing about it.
There wasn't all that much else, but as usual things took longer than expected. I took a lot of time to run my trolling motor wiring, drill the hole and mount the trolling motor plug, secure the trolling motor bracket, and run the transducer. I used zip ties to run the transducer on the trolling motor, with electrical tape underneath each one, and then I used electrical tape to secure it to the trolling motor cable. After this stuff, I carefully measured and drilled the holes for my pedestal seat base, and thankfully all 6 holes went through both wood and the aluminum frame underneath the deck, so the pedestal base is VERY secure. Then I screwed the decks and floor to the boat, added a rod strap, and really that was about it.
All I really want to do is replace the inline fuse I installed for the trolling motor with a Bussmann manual reset circuit breaker, as recommended by some of the folks on this forum. I hate the fuse holder I have, it's very obviously not a good choice for this application. Also I plan to get an outboard sometime in the next couple of months, the boat is rated for 15hp but I think I'll be happy with a 9.9hp.
This has been a very fun and educational project. I know I will do another in the next few years, maybe sooner. My next boat will be at least an all welded 1448, and actually I'd love to get a 16-17 footer. I don't regret going away from my original idea which was adding compartments and other bells and whistles. I scaled the project back to be what I felt was reasonable based on my ability and experience (or lack thereof). I'm sure my next one will be different/more elaborate, but by then I will have spent a lot of time fishing out of a tin boat. I have bass fished for many years, but all of my experience to date has been out of big glass boats (my first boat was 18' with a 150hp). In this economy, I am thankful to have a tin boat versus a big rig. I think I can catch just as many fish and have just as much fun, if not more. Will this boat be too tippy with the way I've built it? I can't say. I did fish while standing on the front bench and it was fine, and I figure if I have a butt seat to lean against while standing, that can only help. Will there be enough room? 90% of the time it will be just me and my dog, so yeah- there's plenty of room.
I will post some more pictures once I get her out of the garage during daylight, which may not be until around Christmas. Sorry that these pics look almost just like my last update/mock up pics.
Also I'm attaching a "before" pic so you can see the difference between now and almost 3 months ago when I started.
