- Joined
- May 15, 2010
- Messages
- 3,672
- Reaction score
- 330
- Location
- Central Florida
- LOCATION
- Lake County, Central Florida
If you want to run shallow you need to put as much square feet of hull on the water as possible and keep the weight down.
This means go longer and wider but do not load excess weight in the hull. Several of the tins had tunnels built into them and this is the way to fly if you want to get on plane and maintain plane across the skinny stuff. These combinations do not take much horsepower to do the job and will be on plane in nothing flat if you keep engine weight down. Remember that every boat is a compromise and doing what you want to do means sacrificing in other areas. There are several Bayou area aluminum boat manufacturers I would check out. They have been there and done that already.
