Troutman3000
Looking good man. Hopefully it warms up soon for you.
Ta5teless said:Hey instead of Wood I am using an Aluminum Extrusion.. https://www.modtool.com Joe Alanari, He's in Troy MI.
My last 1648 I used his extrusion and it worked great!! And it held up the the riggers of my fat hind end!!!!! I am picking up my next project a 1870 and I plan on decking it out with the extrusion as well.
Feel free to e-mail me at [email protected] for any questions
It's really easy to use, drill, tap and modify. Joe has all kinds of fasteners that are easy to use!!
Rat said:Lookin' good, that's a lot of deck space! Sealing is a pain, but, as you know, well worth it. Are you planning to put foam under the sole and how are you planning on draining the cockpit to the bilge?
dyeguy1212 said:No, because I need the sealer behind the brackets, and in the screw holes (most importantly). I'll leave the brackets that are attached to the boat, but the rest has to come out.
Troutman3000 said:dyeguy1212 said:No, because I need the sealer behind the brackets, and in the screw holes (most importantly). I'll leave the brackets that are attached to the boat, but the rest has to come out.
Are you sealing the inside as well? With what?
dyeguy1212 said:... I wish I could find some sheet metal for cheap for the front decks...
